2000 silverado
moose192
Have a 2000 silverado 1500 with a 4.3 has a P1133 code changed the O2 sensor was bank 1 sensor 1 still runs rough smells like rotten eggs . Was told it's a ground issue are these grounds at the VCM or are these grounds to the block or frame. Thanks
I sounds like a problem possibly with the Cat. converter. When they clog up they will emitt a sulfur (rotten egg) smell. I'm not sure about the 2000 Silverado, but my 4.3L sonoma had another oxygen sensor just behind the cat (toward the rear of the truck). That sensor usually doesn't have to be replaced UNLESS your Cat. converter is failed or failing.
Here are some causes of the that code. Make sure you oil fill cap is on and the dip stick is fully seated.
An improperly installed air cleaner outlet duct
The air cleaner outlet duct that has collapsed ducting, restrictions, or a missing or plugged air filter
Throttle body and intake manifold vacuum leaks
A damaged or blocked throttle body inlet
Exhaust system for corrosion, leaks, or loose or missing hardware. Refer to Exhaust System Inspection in Engine Exhaust.
The HO2S is installed securely and the pigtail harness is not contacting the exhaust manifold or wires. Refer to Heated Oxygen Sensor (HO2S) Replacement .
HO2S contamination
The vacuum hoses for splits, kinks, and proper connections
Excessive water, alcohol, or other contaminants in the fuel -- Refer to Alcohol/Contaminants-in-Fuel Diagnosis .
VCM sensor grounds that are clean, tight, and properly positioned
    Patrick Fergy
    Patrick Fergy
  • Who's Online   2 Members, 0 Anonymous, 974 Guests (See full list)
