replacing rear brake backer plates
djabsrev
My 2003 Denali with 92,000 miles needs new rear backer plates that protect the rear rotors, etc. Mine have only from the 10 o'clock to 2 o'clock position left. The junk metal has even found it's way to grind on the rotors. Love the truck, pulls like a mule, has had a wide host of problems from day one. Now that I'm out of extended warranty, I need to do more myself. New "a" tech at dealership has been great pointing me in the right direction, and beer buys his time explaining a few time saving directions. Any help out there without having to split rear end diff and pull axles? Parts are only $22 each!!!
I replaced mine on my 2000 ECSB 4x4 at 100k miles. Mine were toast. You do have to pull the axles. While I was in there, I also replaced the parking brake shoes and the axle seals. It's not too hard of a job, but is nevertheless a pain.
    hotfish
    hotfish
  • Who's Online   5 Members, 0 Anonymous, 815 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
