Ugh! I can't get a straight answer...
I have called Axxess, JPCustoms, and others...
I can *not* get a straight answer from ANY of them!!
I have a 2006 Sileverado 1500 with the "Radio with CD" (This means I have a radio, and a single cd in my dash board. I do not have XM and I do not have a disc changer in the vehicle.
I have a button on my radio (the # 5 preset) that has the number "5" at the top and a picture of something that looks like a disc of some kind.
I do not know if my radio is "changer friendly" and I don't know if the radio is "XM friendly" -- all I know is that it is all stock and I would like to add an Axxess iPOD Interface #GMIP-01 to my truck.
I called axxess (Metra) and after getting a *VERY* unconvincing "Yes, it will work" 9being put on hold a bunch of times, the person on the phone simply wasn't sure) -- I called other places and was told it won't work.
Does anyone here, know, for sure if it WILL or WILL NOT work?
Thanks for the help,
Pete
Pete
if that interface is runs through the satelite connection, just pull out your radio to see if you have an area for a sat connection. It will be a little square like the radio plug, but smaller. If you do, it will work.
    Fishboat
    Fishboat
  • Who's Online   2 Members, 0 Anonymous, 521 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
