Low Idle??????
Dragon Slayer
There is no spec. The idle speed is whatever the PCM wants it to be at the moment based on all sorts of factors. 550 sounds about right though.
They're not electric motors that run so smooth you can't feel 'em, so maybe what you have is normal.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,003 Guests (See full list)
