2007 1500 headlight patern
I just bought my 2007 new body style 1500 and found that the front light patern is shaped like a V on the road in the front of the truck. I looked at it last night and found that there is a reflection off of the side closes to the grill of both lights. it almost looks like the lights are pointed in to much. I thought at first the light was reflecting off of the front grill. I moved the grill back but it did not make a diff. Does anyone have a pattern like this or should i take it in to have it looked at.
I was looking at mine carefully tonight and I didn't see what you are talking about. My headlight pattern is pretty even except for a tiny bit of uneven coverage right off the bumper but these trucks are up high enough for that to be expected. I assume the adjustments for the lights are inside the hood at the back of the housing? May be worth having it looked at.
Thanks for the feedback. I tried adjusting the lights last night and the only adjustment I could find was the up/down, so I played with that and it did not make a diff either. The reflection is definetly from the light assembly on both lights. I have never seen a partern like this before.
    appletrav
    appletrav
  • Who's Online   5 Members, 0 Anonymous, 353 Guests (See full list)
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
