leaking fuel pressure regulator?
RickC10NY
I have a 1998 pickup with a 4.3, It has about 160,000 miles on it.
a few days ago I started getting a very high idle (about 2500) whether hot or cold
I had a PO102 code for the MAF sensor I replaced it and the idle problem persists.
I pulled the throttle body and it had a lot of carbon under the butterfly.I cleaned it and cleaned the IAC and also pulled the EGR and cleaned it along with the EGR passages.
The other possible cause I read was a leaking Fuel pressure regulator diaphragm The question is : How do i determine if it is leaking? would it leak down with the engine off and be detectable on a pressure gauge? or can I look back through the upper manifold with the throttle body off and see a drip?
Finally the upper manifold looks pretty gummed up inside. Should I go ahead and pull the upper intake and clean it out?
Thanks
Rich
Albany NY
    hotfish
    hotfish
  • Who's Online   5 Members, 0 Anonymous, 815 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
