CB Radio Noise
Hi everyone! I got a new CB radio a few weeks ago and shoved the hot wire into an empty fuse slot(has a fuse in the middle of the hot wire already) and put the ground on a little piece of metal behind the dash. Whenever I turn the car on, I get alot of static. When I lock my locks and turn the windshield wipers on I also get a quick bunch of static. Anyone know how to make this go away? Thanks!!
It's being created because you're varying the electrical draw through the fuse box. If you listen carefully to older car stereos, you can hear it in those too. I usually avoid it by hooking into the wires for the cigarette lighter. I've never had a problem doing it this way.
You need a clean source of power to keep the noise down. There are also filters that you can add to the alternator to reduce the whine-like noise.
Where is the antenna located? If it's too close to a motor (like the windshield wiper motor), it can pick up noise from that. A good antenna ground is just as important as is a good power ground for the radio. I would extend the radio ground lead out to a heavier piece of metal like a fender or a large piece of the framework under the dash that is bolted or weleded to the firewall.
The cigarette lighter (or the accessory outlets) works if you want a always-on power source.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,283 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
