Heater Stays On....
chud53
just wondering what could be causing this, but it's really weird ill be driving with the heater on and i get hot and wanna turn the heater off so i turn it off and turn the Temp. dial to cold but yet the vents still have hot air coming into the truck, im not sure what is causing this. And no im not an idiot this has been happening for awhile and im wondering how i can fix it. Thanks for any input
same issues here, I replaced the heater door actuator, I think thats what its called. Now I get cold air on the cold side of the knob, and hot on the hot side. But no blending of the temp which is kinda stupid. I think I have a fulty new actuator......
At least you have actuators.
Mine is manual. Manual as in, you can hear the door flap turn as you turn the indicator.
Kinda nice for no vaccum, but there never is a true setting...you can always still feel air coming out of every duct.
yeah thats how mine is, the air never really shuts off. I can still feel the hot air coming through the vents even though its off. WTF!!!
Sounds like a common problem since mine does the same thing. Mine only does it once in a while though. It's very irritating because when you turn the fan OFF, air still comes out, and if it's hot, the truck gets very hot. I remember a couple threads about this problem, but I can't find them.
Mine does this too. It doesn't happen all the time and sometime when it does I can apply outward pressure to the temp dial and make it cool down, other times I have to stop the engine for a while and it will work again. Also, when it does do it, it really gets hot. Hotter then I can make the heat go when it is functioning properly. ????
I don't know how plenum doors work on my truck - they can be cable, vacuum or solenoid controlled. The only way to learn how to close off hot doors to the heater coil is to get under the dash and observe the doors while you or a helper activates the controls. You can also buy the trucks manuals and get a good description of how they work.
Sometimes a plenum door can be jammed by a wire; or a vacuum actuator may be leaking vacuum or may be disconnected. Check fuses too.
    • $5.19 for regular...
    • My office is slowly filling with Blazer parts. Getting ready to do the big bang of repairs. Intake (second time), water pump, radiator, hoses, and I'm going to re-seal the timing cover where someone went hog wild with silicone. Might as well, because I don't think that's done right.   There's a local tow yard that I didn't realize also has quite the inventory of junk vehicles. This is an old school junkyard. No waivers. Cash only, you were never here if anyone asks. Don't piss off the owner, or you'll end up in the back of one of those cars, headed for the shredder. And if you see something, don't snitch. Cars stacked double high, wasps nests, trip hazards and junk everywhere. I found a few little odds/ends for my Blazer. The $20 I spent was worth the experience alone. But I was never there. What yard?   I officially love/hate this truck. It's so out of my wheelhouse, roughest vehicle I've ever owned. Every. single. repair. -is so hard-fought, everything that can go wrong, goes wrong. Currently in a hate phase, and kind of wish I was closer to sending it down the road with a lucky new owner, to be honest. Preparing for the day when I tear into this thing...lots of pre-funk with Ibuprofen.   Rock Auto sent me a bad reman rear wiper motor. It was a bear to install. The tailgate in these things has about eleventy-billion fastners and pieces and things that need to be uninstalled/moved just to access the shoddy rear wiper motor. The casing on mine was cracked clean through, btw. Nice, GM, nice. SO I got this new motor installed, hit the switch, I see it wig-wag (without the arm installed) and think I'm golden. Reassemble everything. With the wiper arm installed I gave it one final test. Time to clean up and take the other half out to dinner, collect a paycheck, right?   Nope. I hear the plastic worm gear stripping as the arm hung up. Just like my broken motor. Weak/old and shredding itself internally. I can assist the arm and the range of motion is normal, and it parks correctly. It just doesn't have the poop to actually sweep the arm with a blade on it. Oh, hell. Turned the key off and shut the shop door behind me. I get to do that over again, too.
    • A complete delete is the most thorough mechanical solution, but it is also major engine work. On a quiet truck that is still under extended warranty, opening the engine purely as prevention is difficult to justify. A plug-in disabler stops commanded cylinder deactivation, but it does not remove or repair the collapsible lifters, so it should not be treated as failure insurance. I would keep the oil full, document the maintenance, and have any persistent tick, misfire, or loss of power diagnosed promptly. If the engine eventually has to come apart, that is the logical time to compare an OEM-style repair with a complete delete. The right choice depends on the truck’s symptoms, warranty status, expected ownership period, and whether the engine already needs to be opened. We explain that decision in more detail here—full disclosure, this is our own guide: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler   One exception: some 2021 L82/L84 trucks have RPO YK9, meaning cylinder deactivation was already disabled in the factory ECM; on those trucks a plug-in disabler is redundant, although the AFM/DFM hardware remains inside the engine.
