multiple misfires detected, thoughts?
Hey folks.
My bro has a 96 sierra, 2wd, 5000 vortec, automatic truck
He seems to be having a sputtering problem at cruise speeds.
He got a code, states, multiple misfires detected.
Hes done the usual maintenance, plugs, wires, cap rotor, coil.
I know this is a shot in the dark, any chance this is common with this engine/ model truck and there is a common fix?
Any thoughts?
Has he done any recent mods to it like add an alarm system? What type of plugs are you using?
We need just a little more info than what you have given us. Did the thing just start misfiring out of the blue?
  • 1 month later...
My brother's pickup had the same problem and it turned out one of his injectors was bad. The hose that comes from the injector body had a small crack in it. But that was only on the #3 cylinder and the misfire code was the same.
2000 5300 was doing the same thing. Scan tool showed no sensor problems. I had been sitting on a fuel pressure tester for a solid year. Checked pressure using book as a guide. Ended up being the pressure regulator. $75. fix for a part the size of your thumb. Was easy to change though.
    needafix
    needafix
  • Who's Online   4 Members, 0 Anonymous, 475 Guests (See full list)
