$189.99 tuneup
Hey guys,
Is this the standard tuneup? My truck is at 111,000 and getting 11 mpg so we're getting a tuneup. The tuneup we're getting includes the following:
Spark plugs
Air Filter
PCV Filter
Fuel Filter
Fuel System Cleaning
Is there anything else that normally comes with a tune-up? These guys have been really good to us when I had my S10. Any specific brand I should ask for in terms of plugs and filters?
Is that a dealer or private shop? Where are you located? No profile info!
Price sounds pretty good.. Plugs from a shop will run about 8-10 each plus installation, SF about 30 installed, Fule filter about 50 installed and FS Cleaning anywhere from about 75 to 150.
Sounds like you are getting off cheap.
If you can specify what to use stay with ACD in your general.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,003 Guests (See full list)
