'97 6.5TD
Hey all,
I'm going to look at a '97 6.5TD/Auto Extended Cab 2WD.
What should I look for with regard to the 6.5TD.
I recall these motors having issues with the lift pump.
Miles are reported low 76,000.
Any help would be great!
Thanks
Canadian
    Brendan C
    Brendan C
  • Who's Online   3 Members, 1 Anonymous, 1,183 Guests (See full list)
