Fuel Filter Reset code
magrifles
Good Day.
What is the combnation to reset the computer and make the change fuel filter message go away. The
owners manual has a great discription on how to change the fuel filter on my 2005 Duramax but they
left how I can reset the computer... Any help on this??
Thanks
Art
hey- I am thinking that you have steering wheel controls, and I'm not a 100% sure on this, but i believe that if you access your fuel filter monitor in the ipc by your controls in your steering wheel you should see that fuel filter life will read 0% and then if you press your arrow button and hold it. The ipc should read fuel filter life reset then should show 100%. Remember that the fuel filters on the d-max should be changed every 15,000 miles I'm not sure if you changed it yet, but if your monitor is reading 0% I would recommend changing it. hope this help you out -WCT :loser:
hey- I am thinking that you have steering wheel controls, and I'm not a 100% sure on this, but i believe that if you access your fuel filter monitor in the ipc by your controls in your steering wheel you should see that fuel filter life will read 0% and then if you press your arrow button and hold it. The ipc should read fuel filter life reset then should show 100%. Remember that the fuel filters on the d-max should be changed every 15,000 miles I'm not sure if you changed it yet, but if your monitor is reading 0% I would recommend changing it. hope this help you out -WCT :chevrolet:
Thanks for the info, I don't have the info center so I have to do the dance with the foot pedals and the key... I did find the info on another forum.. Goes like this:
Turn the key to the run position
Wait 5 seconds
press the break and throttle all the way and hold for ten seconds
turn off the key
The system is now reset and the message should not be displaied again...
Art
hey- I am thinking that you have steering wheel controls, and I'm not a 100% sure on this, but i believe that if you access your fuel filter monitor in the ipc by your controls in your steering wheel you should see that fuel filter life will read 0% and then if you press your arrow button and hold it. The ipc should read fuel filter life reset then should show 100%. Remember that the fuel filters on the d-max should be changed every 15,000 miles I'm not sure if you changed it yet, but if your monitor is reading 0% I would recommend changing it. hope this help you out -WCT :driving:
Wait 5 seconds
turn off the key
Art
I wasn't familiar with that procedure all the ones i have seen so far had the info center thanks for the info
