noise in front end
slimnottygirl
My 2002 trailblazer started making a sqeaking, growling noise in the front end yesterday when i was breaking. this only happens when i am breaking and not when hitting bumps or anything. to me it sounds like a dried out spring or something like that so today i took it to the garage and they really didnt know what it was, they oiled the whole front end (brakes, upper and lower ball joints) after all this my truck is still making the same noise. they now want to replace my ball joints as they feel it may be this i am not really wanting to let them do this yet as there is only 50 000km on the truck and to me it dont sound like a ball joint do you have any suggestions or ideas as to what it might be or how i can get rid of this. again it sounds like a dry spring, sqeaky sway bar etc...
You might try oiling the upper and lower "A" arm's pivot points with some Liquid wrench,WD-40,etc. It could also be that your brake pads need some "anti-squeal" lube applied between the backside of the pads and your brake caliper pistons.
Well after many hours at the garage, a new ball joint and lots of oil they have found the noise. This noise is my bussings on my sway bar they oiled them and the noise went away but after a couple of days they are back so they are going to replace them. It wasn't cheap but the truck is quite
Just some info about WD-40. It isn't a good long term lubricant. Fine for short term and moisture displacement, but that's about it. Lithium or silicone lube would be better.
Liquid wrench is a penatrating oil, more for breaking rusted stuff loose, again, not too good for long term lube.
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 730 Guests (See full list)
