Roadmaster Active Suspension
3/4 and 1 ton trucks need all the help they can get - and this is the ticket - helps great on corner sway, adjusts to loads and  prevents hop and bounce - the difference is obvious right from the first corner. These are the sway bars that we can't get.
http://www.activesuspension.com/
Easy install, if you have the tools, Sears is very happy with me - needed a very large 1/2 socket wrench and 15/16 socket to get the U bolts loose. Wish I had an impact wrench/compressor.
Another plus, I sweated off 5+ lbs doing the install in 99 degree weather. :D
You can get an electric impact wrench from www.notherntool.com or  www.harborfreight.com to accomplish many tasks and not need the compressor. $49 and up
http://www.northerntool.com/cgi-bin....br=6970
http://www.harborfreight.com/cpi/ctaf/Disp...temnumber=31877
240 Ft. Lbs. of Torque
New industrial design with a 7 amp high power motor hits bolts with 240 ft. lbs. of torque. Rocker switch for one hand forward/reverse.
Drive: 1/2''
Volts: 120
Amps: 7
Impacts per minute: 2400 BPM
Maximum Speed: 2100 RPM
Maximum Torque: 240 ft. lbs.
Length: 9-1/4''
Tool weight: 7-1/4 lbs.
Shipping weight: 8.4 lbs.
I've got one of the ones from Northern.  Not sure you would want to do too much suspension work with it.  I am spoiled by my Craftsman 600 ft/lb unit.
Drive: 1/2''
Volts: 120
Amps: 7
Length: 9-1/4''
Thanks, wish I had found that 5 lbs earlier, oh well, my doctor will be happy :D
Thanks for the recommendation btw!  That's what I was waiting on.
If you think that is good, took it to the track tonite 88+ degrees, ran twice, 14.95, made a difference for sure, last week, same temp/humidity 15.2 - sort of a caltrac for the big trucks :D
And the trip there and back was like riding on velvet, I am impressed :D
BTW, beat 2 out of 2, left when the nitrous guys showed up.  :blush:
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,266 Guests (See full list)
