seat cover questions-which kind?-
did quick search, didnt come up with much. at work on a tablet pc so please excuse the typing style..takes forever..
1. what kinds of seat covers are available that DO NOT loose the seat shape. i love my bucket seat shape and dont want to end up with a soft square like some covers. will neoprune (sp?) be thin enough?
2. is it worth th cost to get neopune if i only get the seats wet or muddy ~20 times a year?
3. will any seat covers help prevent ciggerette burns? are neos strong enough?
4. can you vaccume neoprune covers or are they flexible rubber stuff (more for sand at the beach than anything)
5. finally, roughly how much would they cost for a bench front, 60-40 w/ armrest crewcab?
thanks in. adv guys
I would recommend coverking seat covers. They are custom built and fit great.
Here is some info
Cover King Seat Coverse
Great thank you, I think I will use them if I do get some. Will I need to remove the seats and use fabric screws for these or do they just "slip" on?
Will the neoprune prevent cig burns?
Is the neoprune thin enough to keep the style of my seat, or does it give it a different blocky feel like some thick covers?
thanks
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 716 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
