Chev Suburban 7.4L codes
My dad has a 97 burb with a 454. He has a set of Gibson shorty ceramic headers with hi-flow carsound cats, and a banks muffler and tailpipe. He is getting two codes, P0171 and P0174. I thought I read P1071 and P1074 but cant find any info on those, will read them again next time they pop up. But 171 and 174 are the left and right banks running too lean. I am guessing this is from the increased flow of the exhaust and intake (Airaid). Is there anything that can be done so the ECU doest think there is an issue from the increased flow? One other thing of note is the plugs looked a little more fouled than they should, they are OEM replacment, but not sure if they are the 100K ones. Could old O2 sensors be the culprit as well?
Thanks for the info, I am an avid toyota forum poster, but new here and just helping my dad out. I did search and found nothing of note.
Well you've got two oxygen sensors that agree so I dought they are the problem. Even if they were slow or not responding you would have codes for that.
You need to do two things, first Check over that air induction system for any loose connections, holes, or vacuum leaks. All of the hoses & clamps, PCV lines, intake gaskets etc. Any source of fresh air that isn't being metered through the MAF will cause a lean condition. Remove the MAF and inspect the screen for any damage and spray the insides down with electronic or brake cleaner only. Let it dry before reuse.
Then ensure that the fuel supply is adequate for the task. Install a new filter, then check pressure at WOT, get the inectors flushed out.
That's how to attack a lean condition on both banks.
Vernon
Vernon
I will look into that. I think it has to due mainly with the headers as it started as soon as they were installed. I will have my dad check the intake. The ECU is overcompensating which is why I think the plugs are fouling evenly.
If there are exhaust leaks anywhere near the O2's then that is the problem. The leaks constantly switch from blowing out to sucking in. The fresh air sucked in will totally lean out the O2 readings and the ECM will go over rich to try and correct a false reading.
Make sure the headers are sealed up good.
Vernon
    Brendan C
    Brendan C
  • Who's Online   3 Members, 1 Anonymous, 1,183 Guests (See full list)
