pcv valve question
I found the pcv valve and was wondering if it can be replaced with a rubber one or do they even make them in rubber for a 2001 chevrolet. Also is it wise to replace the pcv valve, I have 91000 miles on my truck and it will it help performance any?
I do not think I have ever seen a rubber PCV valve, maybe plastic. The PCV you go back with should be a metal one and more than likely yours should be a "fixed orfice type" which does not use a check valve. It simply has a small hole in the bottom. If yours is a fixed orfice style and it is clear, there is nothing that needs to be replaced.
I cannot see how a PCV will improve performance. If it were severly clogged you could get some oil blow by and possibly some oil consumption.
