one ton tire sizes
I just got rid of my 2001 ECSB 2500 hd 4x4 6.0, and bought a 2002 CCLB Dually 4X4 Dmax/Allison.....
my question is how big of tires can I go.....I like the BFG A/T K/O in 265/75/16 due to the fact they offer an E-rating, and also a Black wall only option.....which would help in tire rotations for the Dually....most tires are raised white letters on one side so if you rotate dually tires you end up w/sometimes black wall on front, vise-versa....anyone have pictures?
    hotfish
    hotfish
  • Who's Online   5 Members, 0 Anonymous, 815 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
