Odo Wont Shut Off
2000 Chevy Silverado
I recently had an alarm/starter installed Im having a problem with my odo light staying on after the truck is shut off as well as the message center Battery light staying on, they will not turn off no matter what I do would anyone know what this problem is stemming from?
Hmm, not sure but maybe when the alarm was being installed, the installer messed up and accidently switched your wire to those accessories to constant 12v instead of just ignition....check where the installer plugged the power for the alarm into....
    Fishboat
    Fishboat
  • Who's Online   2 Members, 0 Anonymous, 521 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
