Will 35s Work?
I was wondering if you guys thought 35s would fit on my truck....?
I used ford keys with rough country add a leaf but am not sure how much lift i got out of it. Tires on it are 265/75/16 i believe back and front are two different brands back its good year wrangler TD
You can stuff 35" tires in there if you keep stock wheel's.
You will have rubbing issues usually the type trimming can resolve.
Aperence wise though it may look like to much tire for your height
Thanks for the quick reply. I was thinking of getting 18s...why do you say keep the stock rim? I dont mind trimming im just looking for advice..what size tire would you say?
go with a good 33 incher 285 series
i agree 35's would be a bit too much 33's would look good
Thanks for the input....my buddy was saying i should get 35s but i think 33s will do. Just want to fill up that wheel well a little more thank my 31s do. whats a good size for 18s? i have 265 wide right now and they grab pretty well should i get a tire with a little more sidewall.
You'll need more lift for 35's, otherwise you'll run into problems. Do not go with smaller than 18" rims, because most likely you'll need to get better brakes, that will not fit in factory size rims.... That is where I am stuck right now, after $1700.00 on rims and tires
