04 6.0 Random Miss Fuel Fowling Plugs
dragonrider
I have a 04 6.0 g3500 express 17ft 198,000 miles.this is a random miss only above 50 mph to start.Outside temp has to be above 45 degrees. because of my work it I have to run for 2 hrs,it gets worse,some times if I wind her up it will clear for a few miles.It will finally get to where it is at idle.If i shut down for a few minutes,some of time gets better.It seems to start when at cruise,low gas pedal,[high vaccunm?].It started with my thinking it was bad gas.I was bad about over filling it,didn't know it was a no no. Gm dealers said it had a miss cyl 3 and 7,and because it had non GM wire it was the wires.changed no difference.Then was told #8.then #4&2[ now have gas in oil going to change it] Now the shop foreman says he has had a lot of fuel pumps go out and with my miles thats proably whats wrong,but how does a fuel pump fuel fowl the plugs?I see what i think is fuel around the vapor cannister,but it looks dry tranny is there so when I smelled it could not be sure as it melted the under coat.I then ran truck 2 days with out the gas cap,ran great till I got on brakes real hard then hard excell,now its back.Again the only consistant thing is above 45 degrees out side temp.sorry for length but would rather give too much then too little info.please help i earn my living with this truck,$600 fuel pumps come dear Dragonrider
I would replace the cannister. It is probably full of gas from over-filling. The purge valve is pulling the extra fuel from the cannister fouling the plugs. The purge valve is only turned on when certain conditions are met, that is why it does not alway happen. From now on, when the gas nozzle cuts off the first time...Stop filling.
Ty for the reply,now a update.Running with cap off when hot helped,but scan showed #8 missing.Cleared codes then the weather changed,cap on [rainning] temp below 65 truck has not missed or set code.scan says IAT at 60 degree,before when it was 70 it showed 105.I am thinking the evap system caused problem,but maybe #8 has a problem [has new plug and wire.going to put can and control on,then if #8 only shows work on just it
  • 4 weeks later...
Update and answer.
I finally discovered that the wiring harness had rubbed a spot on the #8coil feed wire,also had rubbed injectore wiring.one small spot less then the size of a pin head.it would move because of bumps in road etc,temp was because the dipstick tube was the point or short,but in cold weather the harness was stiffer.just goes to show,OBD2 scanner does not always find the problems,you have to look and think
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 309 Guests (See full list)
