Weird Missfiring 99 Tahoe Problem, Help Please!?
tomrex
Ok so I'm going to do my best to describe what's happening. The other day, I decided to hose the engine off of my Tahoe. I did so, and to my expectation it started missing and the SES light came on with a P300, random cyl missfire. Cleared the codes, let her run for a while and shut it off for the night. The next day it was worse so I changed the cap, rotor, plugs (ac platinum), wires. It was better at first, but went right back to missing. Pulled the cap off, made sure everything was dry and clean, and put it all back together. Still doing it.
My observations.
1) I can start it and it will run fine for about 30 seconds and then start stumbling
- with this, i can watch my scanner tell me that fuel trim in bank one starts to fall off
- Before it happens, a slight miss happens twice before the computer shuts off the fuel on that bank
2) If I drive it, it's a dog and runs on 4 or 5 cyls for a few seconds, and then takes off like a rocket when the others suddenly decide to kick in (then the fuel trim goes back to normall).
3) If I run it hard for a few minutes, it seems to go away and drives perfect. As soon as I let it idle for a minute afterwards, sometimes 2, it starts to stumble again. If I shut it off and restart it, it happens faster. I ran it for 50 miles on the highway yesterday and I thought it went away, but it's back again.
I guess what I don't understand is why, when I lay into it it stumbles and then kicks back in like someone turned on the lightswitch for the other 4 cyls. Any advice?? The coil is looking pretty nasty and is fairly cheap, I think i'll replace it today. Also, I am planning on pulling the new plugs and gapping them. The guy at NAPA told me they were pre-gapped, but I think he's full-of-it.
Any Help would be appreciated.
thanks a million!
Tom.
BTW - It's only got 76k on it, 4x4, etc...
I also forgot to add that compression is great and just did a full SeaFoam douching...no luck. I drove to school today, missed until I stuck it to the floor, chugged for a second and then again, like a light switch, they all came to life. It happened twice and then didn't miss a beat the rest of the way to school...i'm sure it will do it when i get out though.
Thanks again.
Tom
Oh boy oh boy... I think I fixed it. I did some reading and searching on here and was praying to everything and everyone that it wasn't injectors or an intake gasket. I wound up pulling the passenger side (pre-cat) O2 sensor and it seems to run great with short and long term fuel trims consistant. Not a miss, shake, or burp. How come the SES light didn't get an O2 code when it took a crap? Should I leave it off or replace the sensor? Thanks again! Tom.
  • 3 weeks later...
I think it could be that you have a bad connection at the O2 connector. When your O2 is connected and the computer is expecting it to work, it supplies wrong intermittent data. When you disconnect it and consequently the computer seses it obvioulsy disconected, the computer turns the system into open loop system = your truck runs without any emission monitoring on factory preset values. Most vehicles run great like that but that isn't great for your cat.
So for my part: my advice check the connection of the O2 sensor. Maybe it is oxidized or something.
    • $5.19 for regular...
    • My office is slowly filling with Blazer parts. Getting ready to do the big bang of repairs. Intake (second time), water pump, radiator, hoses, and I'm going to re-seal the timing cover where someone went hog wild with silicone. Might as well, because I don't think that's done right.   There's a local tow yard that I didn't realize also has quite the inventory of junk vehicles. This is an old school junkyard. No waivers. Cash only, you were never here if anyone asks. Don't piss off the owner, or you'll end up in the back of one of those cars, headed for the shredder. And if you see something, don't snitch. Cars stacked double high, wasps nests, trip hazards and junk everywhere. I found a few little odds/ends for my Blazer. The $20 I spent was worth the experience alone. But I was never there. What yard?   I officially love/hate this truck. It's so out of my wheelhouse, roughest vehicle I've ever owned. Every. single. repair. -is so hard-fought, everything that can go wrong, goes wrong. Currently in a hate phase, and kind of wish I was closer to sending it down the road with a lucky new owner, to be honest. Preparing for the day when I tear into this thing...lots of pre-funk with Ibuprofen.   Rock Auto sent me a bad reman rear wiper motor. It was a bear to install. The tailgate in these things has about eleventy-billion fastners and pieces and things that need to be uninstalled/moved just to access the shoddy rear wiper motor. The casing on mine was cracked clean through, btw. Nice, GM, nice. SO I got this new motor installed, hit the switch, I see it wig-wag (without the arm installed) and think I'm golden. Reassemble everything. With the wiper arm installed I gave it one final test. Time to clean up and take the other half out to dinner, collect a paycheck, right?   Nope. I hear the plastic worm gear stripping as the arm hung up. Just like my broken motor. Weak/old and shredding itself internally. I can assist the arm and the range of motion is normal, and it parks correctly. It just doesn't have the poop to actually sweep the arm with a blade on it. Oh, hell. Turned the key off and shut the shop door behind me. I get to do that over again, too.
    • A complete delete is the most thorough mechanical solution, but it is also major engine work. On a quiet truck that is still under extended warranty, opening the engine purely as prevention is difficult to justify. A plug-in disabler stops commanded cylinder deactivation, but it does not remove or repair the collapsible lifters, so it should not be treated as failure insurance. I would keep the oil full, document the maintenance, and have any persistent tick, misfire, or loss of power diagnosed promptly. If the engine eventually has to come apart, that is the logical time to compare an OEM-style repair with a complete delete. The right choice depends on the truck’s symptoms, warranty status, expected ownership period, and whether the engine already needs to be opened. We explain that decision in more detail here—full disclosure, this is our own guide: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler   One exception: some 2021 L82/L84 trucks have RPO YK9, meaning cylinder deactivation was already disabled in the factory ECM; on those trucks a plug-in disabler is redundant, although the AFM/DFM hardware remains inside the engine.
