Which Gm Model Year Should I Buy?
My wife is looking to buy a second truck/SUV.
Currently we have just my 2004 GMC Sierra 1500 Crew Cab and her BMW.
We own three watercraft (all under 4K pounds) and would like to find a tow vehicle that fits the following parameters;
1. Costs about $5,000 or less.
2. Must have 4 wheel drive / AWD capability.
3. Dependable.
I know the early 90's Yukon / Tahoes had throttle body carbs but we definitely want fuel injection. We have a teenage daughter and only have the need to carry as many as three kids on a rare occassion so 7 passenger layouts are not required. I know GM tweaked the models from year to year in a careful ballance of improvement versus efficiency (i.e. cost cutting moves).
Which models and model years were better than the others in the GM family? Thanks!
3. Dependable.
The early 90's Gm's were fuel injected.......the throttle body's were not carburators.
You will have to keeps your eyes and ears open to find a good reliable 4x4 for under 5k.................they come around though............good luck...... :banghead:
For that price you're probably looking at a TBI (Throttle body injection) truck, from 89 to around 94 I believe. You could probably find a Vortec truck too if you don't mind a few more miles. The old TBIs run forever, though. Don't worry about reliability.
Totally agree with you...........I had an 89 Z71......bought it brand new in 89...............put 400k on it and the only time the hood was ever open was for a couple of tune-ups, changing the oil and putting washer fluid in..........she ran strong from day one.
I had a 1994 Silverado with a 4.3 vortec V6. Did very well hauling my horse trailer (about 7,000 pounds loaded with 3 horses) for several years, almost every weekend. They get decent gas mileage too, mine got about 18 mpg average, and run forever with proper maintainence. My old truck has over 300,000 miles on it, still going pretty good. V6s aren't normally preferred, but you could easily find something like the one I had in your price range.
Good luck!
I concur on getting something with Throttle Body Injection.
It looks like a carb, but trust me it isn't.
I had a 1990 Camaro RS with the 305 TBI and that thing just wouldn't die. I really wish I wouldn't have sold it, but sometimes you make mistakes you can't take back.
It isn't the fastest thing in the world, but it gets amazing fuel mileage and is extremely reliable and easy to fix. You wont be disappointed.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
