'01 Takes 3-4 Times To Start
My '01 Sierra takes way too long to start, a couple years ago it would pop on the first try (Cranking for about 2 seconds each try, holding it longer doesn't help). I only use 93, and recently changed the fuel filter, so I don't think it's fuel. Last weekend I changed the plugs and wires, which did nothing. Anyone have any ideas? Thanks!
Battery is about a year old. Also, I did gap the iridium plugs to the specs of the Haynes manual... maybe I shouldn't?
That wouldn't matter. Hook a scan tool up and check your fuel pressure when u get it started. Check your batter charge level as well. Could be any number of things you might just need a full tune up with wires, cap rotor etc.
Fuel pressure. Check it with key on, cold start.
Should be 60 psi.
Anything below...you are gonna need a fuel pump.
Stop throwing parts at a problem. Find the problem, diagnose the problem, fix the problem
    ballencd
    ballencd
  • Who's Online   1 Member, 0 Anonymous, 431 Guests (See full list)
