Why Is The Dmax Not Recomended For Plowing?
Tuf Toy
Why are the Duramax equipped pickups like my 2006 Silverado 2500HD Ext cab with 8' bed not recommended for Plowing snow? every time I plug my specific rigs info into the plow manufacturers sites "pick the proper plow blade set up" there are usually none recommended. If I swap in the smallest V8 Gas engine in the same rig specifications and it comes up with every plow blade set up under the sun? I figure only a GM tech could answer this properly of from GMs perspective.
Although Im not a tech, the answer to your question is because of the weight of the cab configuration and the d-max weighing more than a gasser. I cant remember all the models that GM does not recommend plowing with but a beileve its Extended cab long bed, crew cab short and long bed models with the d-max. GM thinks a plow will put to much weight on the front suspension causing premature wear and breakage. However all the plows should work for your truck just if you break something and it is caused by the plow it wont be covered under warranty. Hope this helps
Is there a way to strengthen or upgrade the front end to prevent premature breakage?
After their 2500 Dodges fell apart, my nephews have plowed successfully with extended cab DM's for several years now. While plowing they also carry a salt spreader with a full load of salt. I can understand GM's theory though, that is a lot of weight.
From what I understand GM expects you to carry 5 200lb passengers in the cab (Im going out on a limb here but I dont think you need that many people in the cab while plowing :) ). You can crank the torsion bars a few turns if your front end sags to far to the ground. But I havent heard of anyone having problems with the "inferior" GM ifs while plowing.
ive also heard that timbren rubber overloads work well for plows. the have overloads for both the front and rear of the truck. they have a website... timbren.com
I run a body shop and tried the Timbren load boosters on my plow and tow trucks. I liked them so much I became a distributor. They really do work well.
Mark.
With the use of Timbren suspension kits can you run larger tires (the LT245/75/R16's on my '06 2500hd are just pitifully small) or can Timbren kits be used on lifted trucks?
    250.3k
    BDS my HD
    BDS my HD
  • Who's Online   1 Member, 0 Anonymous, 476 Guests (See full list)
    • Hello hello looking forward to expanding my knowledge of the 2026 2500 HD that I just bought.   Truck has 3500 miles on it four-wheel-drive crew cab and I’m about to put a 6 1/2 inch BDS lift on it 18 x 10 -25 offset with 37’s   Already have the wheels and tires just waiting on the lift install in about three weeks   Question what surprises am I not gonna be happy with?  I’m not new to lifted trucks so I know that acceleration towing gas mileage all that is affected..   Question is those of you that have this truck this powertrain with a 10 speed Allison and have done the mods that I’m doing,,, how bad is it? Is that Allison constantly gonna be hunting for the right gear to go into? And what about towing, acceleration, fuel consumption as mentioned?    Lastly how come I can’t find any ring pinion gear set up for these axles and when could I expect to see them?   I apologize if there’s any typos I’m doing speech to text on my iPhone.
    • I've got a 2013 2500 6.0L Flexfuel. Drove the truck earlier today with no issues. Went to run an errand tonight and noticed key fob wouldn't work. Figured battery was dead, so replaced fob batter. Still wasn't working. Grabbed my other set of keys with the other fob and that one wasn't working either. So I manually unlock truck and insert key. Interior lights come on, dashboard lights up, turn key and truck starts. Turn truck off, like a moron, and try starting again. This time no crank, no click, no nothing. Lights still come on and dash lights up, but now I'm getting a service 4wheel drive, service tire monitor, etc. Check voltage on battery and Im showing 12.2v. Throw my battery charger on it and give it 15 mins and try starting again. But still no crank no start. Decide maybe its a bad battery, run to autozone grab a new one and put it in. Same issue. Disconnect battery and let it sit for 15 mins. Try again and still nothing. I had managed to roll the windows down earlier as its a humid night, but now I can't get them to roll up. Power locks are also not working now. Then randomly I try the key again, and it fires right up. Immediately I roll up the windows as we have nothing but rain forecast this week. I shut it back off wait 30 seconds and start up again. Worked a 2nd time. So turn it off, start putting things back together. Try one more time, and back to no crank no start. And now the car alarm starts going off. Had to disconnect battery and leave it that way for the night as I don't think my neighbors would appreciate my alarm going off again tonight. Any thoughts or help would be appreciated.
    • No one will care for you like you care for you. Do what you can for as long as you can. IMHO of course.
    • How about them NICKS!!!
    • Hi there.  Long time lurker, first post.    i have read the previous posts regarding the water ingress problem with this emblem.  I bought my 1500 SLT the  summer of 2025 new and after reading the MANY problems with these emblems failing I decided to install one anyways.  As per a YouTube video, I sealed ( or tried to) this sign with silicone sealant around the outer perimeter joint and the holes that were already somewhat sealed on the rear plate of the emblem.  And installed the connector assembly using dielectric grease on the connectors. The installation looked great and worked well for about 4 months……then FAILURE.  Grrrrrr…… I live in the great white north and wash my truck weekly in an automatic car wash  to keep the salt off.  Let me tell you that removing the old, failed emblem is a whole different animal than removing the OEM individual letters without removing the grill assembly. Mainly because the illuminated logo is built differently than the original letters which  you can remove the red surface lettering with a knife or some kind of blade which gives access to the tabs which hold the logo onto the grill. So I had to essentially destroyed the old emblem to remove it. Doing so killed my chance of doing somekind of autopsy on the failed , old logo.  But there was plenty of water inside when I ripped it apart.  Prior to installing the new assembly I tried it with the old harness and it works fine.   Does anyone have any insight as to where the water is getting into this emblem? I intend to seal the new logo with slow curing epoxy this time around using a syringe.  I think this newer emblem may be an updated unit which I hope GM got the vendor to fix. It has an October 2025 date on it.    If this one  fails,  I am just going to revert back to the non-illuminated letters….AFTER PULLING THE GRILL.    Any thoughts on sealing with epoxy would be appreciated. Thx!   Doug
