Mirror Upgrade
Well I bought the upgraded mirror off ebay, got it the other day. I went to install it and there was no wire harnass above the roof liner. I called the dealer who said he couldn't find anything and then called the company-Gentex which lead me to MIto and they also could not help saying it was too much of a liabilty to just sell harness- :cheers: And said to look in a yard for gm cars that have the same mirror, but there are no good yards around me. So now I have this mirror. I know I need a wire harnass, temp harnass/probe and possible a pigtail of some sort? Any help/part #'s would be great It is a gentex 177 temp/comp- Thanks in advance My wife is going to kill me if I don't get this in she already hates Ebay.
Chris
If it helps it's a 7 pin harnass
this might work for a harness: http://cgi.ebay.com/ebaymotors/7-WIRE-WIRING-HARNESS-Auto-Dim-Mirror-MAP-LIGHTS-TEMP_W0QQcmdZViewItemQQcategoryZ33699QQihZ007QQitemZ170122143054QQrdZ1QQsspagena
meZWD1V#ebayphotohosting
he also has the probe.
also found this:
Red (dark pink) ---- Power ( ignition switched 12 volt)
Black -------------- Ground
Lt. Green -------------- Backup light ( I failed to hook this one up yet.)
Green with Black ---- Temperature probe ( same color at the sensor.)
Brown -------------- Temperature probe (same color at the sensor.)
the light green for the backup light keeps the mirror from dimming while you back. There are two other wires but unless you have the side mirrors they are of no use.
    Patrick Fergy
    Patrick Fergy
  • Who's Online   3 Members, 0 Anonymous, 1,101 Guests (See full list)
