hey guys im wondering if anyone has a shorter or after market antenna i hate the noise mine makes on the highway and my radio signal all of the sudden sucks! it used to be ok but not anymore i even check connections on my aftermarket deck and they were ok. it sucks cuz it only started being fuzzy after they put my new deck in. will an aftermarket deck help with radio signal strength? i already know it will look better and not be as loud on the highway due to the non spinny style.
thanks
kyle
My mom works at a chevy dealership so got one from thier parts department, but if you go to a local performace shop or something they sould be able to get them or give you a place to go that does have them
I eliminated the antenna, got the plastic cover for a escalade, which has no hole, and ran a peice of wire up the a pillar for an antenna. I'll post pics if you want...
Took a long piece of wire and an eyelet connector,
ran the wire up the A pilar and all the way to the back above the doors, under the rubber molding,
and snapped the new cover in place, part# 15287179, $8.41 on GM Parts Direct.
Radio reception isn't bad at all, and I live pretty far away from anything.
Good luck
Good luck
Great idea. I did this mod today. Im getting radio stations i didnt know existed and the wind noise is gone. What size nut did you use? I jst have it stuck on there for now cause i couldnt find a nut that fit.
I don't remember. It was an odd metric size I found at Ace hardware. I took my antenna in, found a bolt that fit it, then got the nut for that bolt. It was an odd size of course.
Good luck
is the part number you listed going to work on the GMT-900's?
thats pretty cool, im gonna have to look into that one
That is a way cool mod Guy! :shakehead:
Awesome mod, I'm ordering the plastic cover right now. And I suppose you could run the wire anywhere, even under the hood. Heck, I may not even bother with the antenna since I never listen to the radio. :shakehead:
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 485 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
