Acceleration Problems
My parents have an 04 ranier with the 6 cyl., and when you hop on it, not enough to even be trying to spin the wheels, but enough to get some spirited acceleration, ithe engine will whine and yell like it is actually doing work, but there really isn't any moving being done. If you stay on it it is almost like a switch is flipped and suddenly it is like the trans says "hey I think I want to do something now, but not yet". It will even downshift and hit, but it is like it just isn't pulling. I know GM has TM and everything else in place, but it wasn't always this bad, at times the thing even felt sporty. Any ideas?
  • 3 weeks later...
    Brendan C
    Brendan C
  • Who's Online   3 Members, 1 Anonymous, 1,035 Guests (See full list)
