Header & Exhaust For 8.1
2007 Sierra Classic 2500HD CCSB, 8.1L, Ally 6spd, 4x4, 4.10 gears, 5W Hitch
I have been 'net researching headers and exhaust systems for my new ride and am surprised to have found that many performance equipment manufacturers do not have go faster - pull better stuff for the 8.1.
Being old school and not familiar with chipping etc, my first step in achieving more low end torque for towing, and better fuel mileage all round, is to increase intake and exhaust flow.
I have pretty much decided on a Volant CAI with their new PowerCore dry filter but am running into problems finding headers and performance exhaust from the same manufacturer or determing compatibilty of these components from separate suppliers.
I have also noted at least one exhaust sysyem with disclaimer "not with 5W hitch".
Any and all recommendations welcome.
Thanks
GeeJay
Get a mail order tune if you really want something to wake the motor up. A CAI + cat-back system will really see some increase in power if you get that tune to go with them.
JBA actually offers a set of headers and exhaust system for the 8.1 if you would like to know more about them give us a call and we can hopefully help you with ay technical inquiries you may have
800-830-3377 anyone here can assist
I have also been looking for a new exhaust setup for my 8.1L. At summit racing all I can find is shorty headers. Tbyrnemotorsports has some good stuff he has stainless works long tubes. I have seen alot of talk about TOG(Those Other Guys) hearders on 8.1Ls but I cant seem to find them. I've also been looking at changing my intake to a volant CAI instead of my current airmax. Did you find the volant with the powercore dry filter online? I found the intake for $259 but havent heard/seen anything about a dry filter by them which is really what I want to run. I have also heard many good things about PCM tunes on 8.1s and I'm currently researching them.
After I first purchased my truck I contacted Banks about performance up grades. They told me that they were developing a system for the 8.1L. I'm still waiting for it to come out. They make headers for the workhorse motorhome with the 8.1L. I was told that the factory set up is so good that it did not pay for them to R & D a new system.
  • 3 weeks later...
Don't waste your time/money on shorty headers as they're just not worth the it for maybe 10 HP. Long tubes will make some HP and Stainless Works are the only ones I've found. Waiting for a set for a Suburban now. They make them for the trucks but it won't fit the burb. I'm running a Volant CAI with the snorkel, Ed Wright tune and MagnaFlow exhaust for now but still searching for "more". The other post is correct about the flow rates of the factory exhaust manifolds. Look at them, they look just like a set of shorty headers now plus you don't have to worry about leaks and burning plug wires. One other thing to is I really don't thing the CAI help any in everyday driving, even towing. The airbox on the 8.1 will flow a gob of air. Hands down the "tune" has made more difference than anything, driveablility and mileage both.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
    • PCM?  These don't have a "PCM".  Powertrain Control Module.  They have an ECM (Engine Control Module) and TCM (Transmission Control Module).   Do you mean update the radio?     You can check what version you have in the settings page.  Should be Y181 but there might be a newer build they can update it to.
