Nbs Subwoofer Options
any that will fit where you are wanting to put them .... a lot of the companies make 'thin profile' subs now .. that will fit no problem under the seat ...
as far as i know tho .. none of the 'common' pre-made box companies have one yet for the nbs's ... i have found one person on ebay that sells a box for 200$ with a single sub in it ...
www.subthump.com makes boxes that will hold one or two 10". I have one but it is hard to find a ten that will work well in so little space. They also have a box for two shallow 12" but I've heard the Premier shallow 12" and it sounds like crap. www.proboxrocks.com makes a ported box that holds two 8" that is supposed to sound pretty good. The subthump 10"box is ok but has cheap connectors and very little space. If you want to put a decent sub in there your going to have to go custom. I first put a JL 10W1v2 in the subthump box and it was ok but not enough power. Then I got a Audiobahn AW1000V (cheap but powerfull) and it did not fit. I cut a larer hole in the back to clear the magnet but it still did not sound right. Now I have a regular wedge box sitting on the pasenger side floor with the seat up. It sounds great but looks bad. I'm goignt o wait a little while to see if someone can come up with a better box and if not I'll just have to build a custom.
    Aries68
    Aries68
  • Who's Online   1 Member, 0 Anonymous, 126 Guests (See full list)
