Gmc Logo On Front Of Truck
I wanted to paint the GMC logo on the front of my truck and my envoy, Has anybody done this? Does anybody know what kind of paint to use? I also was thinking od taking the sierra off the back of the truck, Does anybody know how to get that off? Thanks
I used some krylon plastic paint and some clear coat to do the front emblem. Scuff it up with a green scrubby, wash it with alcohol and apply the paint. I would apply a couple coats of each paint. Set it aside, and let it dry for at least 24 hours.
The best thing I find for removing badges off the body is dental floss. Once its off there will be a load of sticky stuff remaining, buy some googone or just use some WD-40 and some elbow grease. Wash the area with dish detergent to get rid of the oil and wax with your usual wax.
Hey nytemare do you take the gmc logo off the front of the truck to paint it if so how do you get that off of there?
Should be two small bolts behind the grill if its anything like a Chevy. Remove the grill and than deal with it...easier than sticking your hands down between the rad mount and the grill.
  • 3 weeks later...
For the two painted GMC's I just taped them off with "blue painters tape" and sprayed krylon plastic paint
Mothers 01 Yukon:
My fathers 06 Denali:
or you can go this route as I did on the HD:
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,271 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
