02 Map Light Fuse Location
Ok here is the skinny, I blew the fuse that powers the center roof console map lights and I can't find the fuse. The listing on the fuse panel isn't clear to me. I would think that it wouldn't be any bigger than a 10 amp fuse, correct? Far short of pulling every fuse out I can't find it. The fuses are not that easy to pull out either with that little plastic puller, any issues using needle nose pliers to pull the fuses? Thanks
Never mind, it has been a long day and the heat was getting to me. I found it after cooling off some and going back under the hood. Next time I'm unplugging the battery before I mess around the electrics. I should have known better. :cheers:
    appletrav
    appletrav
  • Who's Online   1 Member, 0 Anonymous, 273 Guests (See full list)
