Hard Tonneau Top
I got a 97 GMC Sierra Extended Cab and I want a hard tonneau cover for it. I was told that A.R.E. is top of the line, so I priced them and I can't afford that.So I'm asking, what kinf is the best for the money, with a lock so I can use it as a trunk, and something that (un)installs easy so I can put it on and take off as needed.TIA fOR REPLIES
You'll get a bunch of different replies, but I have had mine for 3 years and still looks brand new, it is very light, easy to pull on and off, and very tough. The new ones even come with a battery opereated LED cargo light. Highly recommended.
  • 2 months later...
what kind do you have? How much did it cost?
I recently just ordered a E300 Covermaster for my truck but they also have a model called The Edge thats more of an economy one but with hardcovers there really not economy priced unless you get one of the one-piece black plastic ones
If you want a one piece top, take a look at an "Undercover." Was impressed but didn't get one because they didn't make one to fit a Reg. cab longbox. Got a Bakflip, which is a huge mistake if you expect your stuff to stay dry. It's secure but leaks like a sive.
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
