How Can Figure Out The Backspacing On 20x9.5 20mm Offset Wheel
I've changed my mind about the 285/55/20 BFG and want to go with the Nitto 305/50/20 which is the same diameter but wider tire. Since I don't have the truck yet, I'm concerned about fit/backspacing. I will do a 2" leveling kit and would someday like to move to a 305/55/20 tire (33").
Backspace of the wheel would be determined by measuring the overal width of the wheel, probably 10.5" (9.5 + about an inch for the flange thickness) and dividing in half = 5.25". The offset of the wheel is 20mm or about 3/4" from the center of the wheel. Since you expressed the offset as a positive number, add the offset to your 5.25" = 6". This does not allow for the inch or so that the tire extends beyond the flange.
Thank you, that's what I needed to know. I'm not sure if the offset is positive or negative but now I know how to calculate it once I find out.
Backspace is the distance from the wheel mounting flange to the inside edge of the wheel. Offset is the distance from the wheel mounting flange to the wheel centerline.
A Positive offset is where the flange is closer to the front of the wheel centerline and a negative offset is where the flange is closer to the backside of the wheel past the centerline.
Wheelwidth plays a part in the two measurements, as does the location (and thickness of the mounting flange) of the wheel center within the wheel rim. For a given wheel width, if offset changes, so does the backspacing.
    ar0517
    ar0517
  • Who's Online   2 Members, 0 Anonymous, 360 Guests (See full list)
