How Does The Vvt Work On The L76 Nbs
I am interested to know how the valves timing is changed in the engine. I always thought you had to have an overhead cam for vvt. I thought we just have the pushrod V8? Anyways, someone smarter than me could please explain?
Thanks, josh
Thanks, josh
VVT on Cam-In-Block (aka Pushrod) engines simply phases the cam using hydraulic pressure from the engine oil controlled by a solenoid valve. It does not change the intake and exhaust timing independantly as it does in DOHC engines.
Do we have VVT on the intake and exhaust valves or just on the intake? I heard that is the difference between the 6.0 and the 6.2. That the 6.2 has it on the intake and exhaust and the 6.0 only has it on the intake.
Thanks, Josh
Thanks, Josh
There is only one cam that controls ALL of the valves. The only thing VVT does is phase the cam relative to the crank. It cannot adjust the intake or the exhaust valves independantly or exclusively.
It advances or retards the cam timing based on engine rpms and load to optimize the power/efficiency of the engine. The computer sends a signal to a solenoid, which controls a hydraulic valve, then uses hydraulic pressure (engine oil) to rotate the cam relative to it's sprocket via a rotary vane. This advances/retards the timing accordingly. Make sense now?
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 716 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
