Bad Fm Reception 2007 Yukon
tommbo
I have a 2007 Yukon Denali, poor fm reception. They changed the radio,antenna in the window,and module, checked all bulletins. Still no good. I would like to know if this is a popular problem with this new antenna. I am going to try to ask them to put a mast antenna in if they cant find the problem. also..when I open the rear door, the reception gets perfect, leading me to belive the window antenna is junk!!
Document ID# 1749735
2007 GMC Truck Yukon - 4WD
Subject: Poor radio reception - keywords antenna AM FM mast tool #PIT3839 - (01/10/2006)
Models: 2001-2002 Chevrolet Old Body Style Trucks and Utilities
2001 -2002 GMC Old Body Style Trucks and Utilities
2002-2006 Cadillac Escalade Models
2001-2006 Chevrolet Avalanche, Tahoe, Suburban
2001-2006 GMC Yukon Models
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Some customers may complain about poor radio reception on Full Size Trucks and Utilities. This concern may be related to a loose radio antenna mast .
Recommendation/Instructions:
In an effort to allow the dealer and subsequently the customer to properly tighten their radio antenna mast to the base, a new orange or black plastic "wrench" will be shipped attached to the antenna mast starting mid-April, 2001.Dealers should utilize this tool to properly attached the mast to the base and then remove the plastic orange or black wrench and place it in the glove box for the owner's use later.
Note: The only way to order a replacement wrench is to order a new antenna mast assembly.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
OR
Document ID# 1973305
Subject: Radio - Poor AM and FM Reception (Inspect and Fully Seat Connector) #06-08-44-033A - (05/18/2007)
Models: 2007 Cadillac Escalade Models
2007 Chevrolet Avalanche, Silverado, Suburban, Tahoe
2007 GMC Sierra, Yukon Models
This bulletin is being revised to clarify the location of connector C213 in step 3 of the Correction procedure. Please discard Corporate Bulletin Number 06-08-44-033 (Section 08 -- Body & Accessories).
Condition
Some customers may comment that the radio has poor AM and FM reception.
Cause
The radio antenna coax cable may not be fully seated at connector C213.
Correction
Remove the driver and passenger windshield pillar garnish molding (A-pillar trim) and disconnect the wiring harness.
Remove the instrument panel upper trim panel and disconnect the electrical connections.
Remove the foam tape surrounding the radio coax cable electrical connector C213. Connector C213 is located under the top left side of the instrument panel upper trim panel on all vehicles except the Cadillac Escalade EXT and the Chevrolet Avalanche. Connector C213 is located under the top right side of the instrument panel upper trim panel on the Cadillac Escalade EXT and the Chevrolet Avalanche.
Inspect connector C213 and manipulate coax as needed to ensure that the connector is fully seated (The above graphic shows the connector properly seated).
Install foam tape around connector C213.
If re-securing the connector does not correct the condition, refer to SI for further diagnosis and repair.
Install the instrument panel upper trim panel and electrical connections.
Install the driver's and passenger's windshield pillar garnish moldings (A pillar trim) and electrical connectors.
Condition/Concern:
OR
Condition
Cause
Correction
Like I said all updates have been checked. Can someone tell me if the antenna wire is routed thru the rear of the vehicle, near the back door?
    appletrav
    appletrav
  • Who's Online   4 Members, 0 Anonymous, 281 Guests (See full list)
