Fuel/electrical Problems
hawgwyld
I was driving my truck, and it just up and died on me. I changed the fuel pump, filter, computer, module in the distributor, rotor and cap, and nothing happened. I can pour fuel in the TB and it will fire.
Now, here is where things get strange for me.
I pulled the 3 prong plug on the MAP sensor. We jumped the purple and white wire once the plug was pulled, and the truck fired off. It didnt run just great, but it ran. Like I said, I can pour gas in the TB and it will fire with the MAP sensor hooked up, but dies when it burns off.
We're getting voltage at the injectors, MAP Sensor, and TPS . I talked to a good friend who works at O'Reilly's who is telling me that when we jumped the two wires on the MAP sensor and it fired, all that did was put the computer into default mode, and that it may be that my chip has gone out in the truck.
I'm lost now. I dont have the money to take it to a mechanic, because I've sepnt alot on all of the other parts I have purchased, so I'm really needing to narrow this down the best I can.
I had someone say the injectors are gone out, but like I said, I can jump the MAP sensor, and it will fire. It runs rough, and wont stay fired off long, but it will fire.
Thanks for any help.
Luke
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,003 Guests (See full list)
