Nnbs Dic
As easy as remove old trim, locate harness and plug in, then reinstall by pushing back in place. Install time - maybe 3 minutes..
I was looking online and it said the parts are only $100. How easy is the install
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
