Wheel Offset/tire ? On Nbs Silverado
I am looking at some 22's. On the 07 NBS do we need +30 to +40 offsets for aftermarket wheels? Would +15 to +20 work? I heard the lower offset might rub on a full turn? Would 305/45/22 clear with a non lowered truck and contoured mud flaps? Thanks
Anything you buy in a 22 - 24 inch wheel should be test fitted but it's been our experience that +20 or more should work depending on your tire choice.
I have 20x9 +30 offset wheels with 275-55-20 Pirellis and the tire is nice and flush with the outer wheel opening. No rubbing under any conditions with the 20s. Much less offset and the tires would stick out (which I dislike) and also likely rub at the front when turning.
305-45-22s would be about an inch taller and wider so I would think the offset would be critical.
What wheels (make and specific model) are those on your red GMC Sierra? I have the exact same truck in silver birch, and need ideas for an aftermarket wheel in 20".
Thank you.
Have you called the wheel manufacturer??? The ones I have delt with in the past has all or most of the answers you are looking for. They just don't make wheels without R&D and guess at the application of the wheel to the vehicle.
Thank you.
My wheels are Venti V98 20x9 - I got em because they had a little different look. I had chrome on my previous truck and wanted something with less flash. Look at the link in my sig for a better pic.
Thank you very much. I'll look into them.
    CaptainDad
    CaptainDad
  • Who's Online   3 Members, 0 Anonymous, 487 Guests (See full list)
