Mirror Upgrade To Power Folding W_turn Signal
I have been trying to find a set of painted black mirror caps for a NBS Sierra to match the upgraded painted black door handles I just swapped out. I have searched ebay and it looks like I can get crome or a different color for around $40, which I then would have to paint.
However... I came across a set of power folding mirrors for $100 and guess what they have the painted black caps already on them... :thumbs: I say thats a good deal, but here's why I opened the post.
What all do I need to perform this upgrade? I assume the mirrors are plug and play, but I also need the switch for the power folding feature.... where does this go in the truck? is it below the climate control next to the slippery when wet button? Does anyone know if I can just get the folding power mirror button or am I looking at having to install the adjustable peddle button as a combo.
Anyone do this upgrade? Thoughts? Input? Isite is much appreciated.
Yes.... very relevant! Thank you. Sounds like a cluster f* of an upgrade.... not sure what you have to calibrate, but must have to do with the memory seat option that adjust the mirrors for driver 1 and driver 2. My truck is a SLE1 with SLE1 convienence package... no memory seat. :thumbs:
Anyone successfully completed this change out? Can it be done if you don't have an SLT?
    ballencd
    ballencd
  • Who's Online   5 Members, 0 Anonymous, 713 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
