Electric Brake Control
mshell56118
2003 silvy 5.3 pulling a jayco trailer
I have pulled this trialer many times without any problems with the electric brakes but when i pulled it home yesterday the brakes did not actuate when stepping on brakes like normal i could manual engage them with the slide control. the brake lights come on when the pedal is pressed i checked all the connections and all seem good can someone tell me where else i should check
Just re-read your post, I think I might have misunderstood. If you could manually activate the brakes with the 'manual slide', then I would think that either the controller is out of adjustment, or is defective.
What type of brake controller are you using ?
could be a bum controller, what kind and how old is it?? if you can apply them manualy like you said that the pressing the break pedal should have the same effect
    Patrick Fergy
    Patrick Fergy
  • Who's Online   3 Members, 0 Anonymous, 844 Guests (See full list)
