How To Level Chevy
Ok i have a 89 2500 chevy and i want to level the front end. also i am putting an add-a-leaf in the rear. i want to see some pictures on where to adjust the torsion bars. not sure on what to do to level the front up. also what is the maxium amount of tire can i get on that with 16in. rims.
Thanks, Tyler
Tyler,
Read this article for info on HOW TO: http://www.offroad-tech.com/tech/tb401/
After reading this, I adjusted the stock torsion bar keys on my 05 Silverado Z71---without modifying anything, I got another 2.5" of front lift up front. If you need more than 2.5" of lift, try using the Ford keys outlined in the article. You can get them for about $21 a piece (as opposed to some of those overpriced leveling kits out there...which are nothing more than Ford keys). No matter which way you go, make sure you have your front end re-aligned after changing your lift!
Here's mine...
BEFORE
AFTER
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,208 Guests (See full list)
