Electrical Problem - Dead Battery Over And Over
mikey_b
6 weeks ago my battery dies one day while getting gas. The battery was 5 years old and I had the radio on while fuling up so I didn't think anything of it, I just got a jump. A week later it happened again so I got a new battery from Murreys and thought my problems would be solved.
Since getting the new battery I have had new problems.
Several times when I try to start the truck I can hear the starter trying harder than usual then the gauges flicker and then the radio clock resets to 12:00. But it would still start. The problem is frequent after a short run - like 5 minutes to pull the truck into the garage.
I have had to get a jump start on the new battery a few times because it wont turn over at all.
Do I have a short somewhere causing a drain? On the other hand, I have let the truck sit for a few days while out of town and it started without any problems.
Anyone have any ideas?
Update:
Yesterday I tried to start and got absolutely nothing. I got a jump and it started fine but my volt meter on the dash was bouncing all over the place and as soon as I shut off the engine all the lights died.
I figured either I had a completely dead battery (even though it is only 1 month old) or I had a bad connection somewhere.
Using a multimeter I decided the battery was fine but the connection at the battery had a problem.
The conenctor was all corroded inside the rubber boot that GM put on there to keep the corrosion out. Ironic that the boot not only didn't stop the corrosion but it also hid it from me so i had to take the thing apart to figure out what the problem was.
So anyway, if anyone else has problems like this, check the cables first.
    appletrav
    appletrav
  • Who's Online   3 Members, 0 Anonymous, 373 Guests (See full list)
