Chrome Tow Hooks.
hey guys, the next upgrade for my truck is ganna be some nice and shiney chrome tow hooks.I'm mainly getting the hooks for the looks. there was time I pulled trees, log and other heavy meterials with my old 92 ford.but now if I'm faced with this situation in my sierra, once I hook up the chains to chrome hooks is there a good chance it will chip or crack the chrome?has this happened to anyone?I'd like to know, if the chrome will chip ill jus go with the plane ol black.thanks.todouble,
I Installed them back in May and haven't seen any problems at all. I realize that's not that long ago but wanted to throw this out there.
Daddy
I installed mine late last week and, other than the polished chrome finish, they looked just as sturdy as the OEM black ones that were replaced.
  • 1 month later...
Chrome will be fine, as long as you use a strap instead of chains.
+1^
No chains and no metal hooks and they should stay lookin beautiful.
On the topic of tow hooks, the factory ones look like thet are pretty light duty. Has anyone had problems with bending or snapping?
well id say you could prolly haul cranes with the crome ones. j/k
Are you EVER even going to use them. NO. what could you possible want to tow with your brand new truck and risk scratching or bending or breaking.
now on the older chevys......... i pulled one out of the ditch today by NICE, USEFUL, tow hooks.
  • 1 month later...
As far as strong, yes they are strong, actually straonger than the old style, about half the thickness, but a closed loop, as oposed to the old style which were more hook shaped with an open end.
A closed loop will make getting a strap on difficult unless you loop it through. If you do that getting it off afterwards will be a royal PITA! Think of a knot tied real tight in your shoelace.
Are the chrome tow hooks Centrifuge Rated, like the F-150s?
I'd hate for my truck to fly off a centrifuge just because I wanted shiny tow hooks. Just sayin'.
    appletrav
    appletrav
  • Who's Online   5 Members, 0 Anonymous, 342 Guests (See full list)
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
