For Sale Pac Oem-2 (brand New)
mlopez5154
This was going to be for my sister's car, but went another route. First 30.00 takes it. She paid $60.00 for it. You can email me at [email protected] if interested.
Thanks,
Michael
Part Number: OEM-2The OEM-2 is the one-piece solution for replacing the radio or adding an amplifier to any factory system. By isolating the system, providing a 4 channel signal level converter, an internal remote trigger and a common ground speaker conversion circuit, the OEM-2 is truly a multi-problem solution.
• Adjusts up to 4 channels of signal input from 2 to 60 watts
• The OEM-2 transformer isolates the input and output circuits, blocking DC noise and preventing snap, crackles and pops typical in other products.
• Sealed potentiometers prevent circuit-induced distortion and signal drift.
• Allows for conversion of floating ground head units to match common ground speakers systems.
• Provides an internal trigger to turn on a 2 amp/12 volt power line with a 1second delay for an amplifier or power antenna.
• Deliver linear frequency response /-0.5 dB from 20 to 20,000 Hz, for unparalleled sound quality.
    ballencd
    ballencd
  • Who's Online   5 Members, 0 Anonymous, 713 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
