Faulty Thermostat..already?
Canned Heat
My '07 Sierra Cew Cab with 4.8 came with factory remote start, which is a bonus...but I get going this morning after a 10 minute warm-up and get 2 miles down the road and my temp gauge is reading about 225+/-. It goes up a hair more and comes back down to the 210 norm. It spikes about 3 more times never going above the 230 mark.
The truck has 974 miles on it....WTF?
Taking it in today...
The unpressurized boiling point of coolant is 212 degrees the cap lets pressure build and for every pound of pressure boiling point goes up 3 degrees. I don't know what the cap is rated at but lets say average is 15lbs that would bring the boiling point to 257 degrees. The t-stat opens around 210 and the fan shouldn't even be working till about 220 so I wouldn't really worry about 225. If you are take it to the dealer and with a scan tool they can tell the exact temp the gage may even be a hair off.
Thanks.
Heavy workload in the office...won't get there til later today. The MAX of the temp gauge is 260. I would've shut her down before it got that far. The 225 was a guess, but it got just short of the 3/4 line. At the top, it's 210 and at max it's 260 so it would've been pushing the 230 to 235 range, Either way, that shouldn't be happening to a new truck with short of a thousand miles on it. It is an '07 and probably sat for awhile. I'm sure it's feasible that a thermostat could go on it...just surprising.
Spoke with the service big wig at the dealer....he says this could be common based on the fan or the motor wanting to run that hot. He says it's typical of alot of GM front wheel drive cars. I hate the thought of having to watch the gauge that carefully anytime it's cold out.
The factory gage isn't a very scientific instrument. It really just gives you a general idea what the engine is up to rather than a precise temperature reading... hence the very wide range on the cool to hot scale. My 07 runs about 1/8" beyond the 210 mark when it is hot and my 05 never got up to the 210 mark.
I would certainly keep an eye on it (as you obviously are). Probably not anything to worry over... especially if it never gets any higher. Might bring it up at your next service visit. It is possible that you have a sticky thermostat.
So they replace the thermostat a little while back, and everything's been fine. I get gas this morning and start the truck back up....it's cold out and run in for a coffee. I come out and I can here the fan just roaring and think to myself: "I bet the temp gauge is up" and sure enough, it's around the 225 mark again. I drive away watching the gauge and within a minute it dips back to the 212 mark and stayed there for the remaining 26 miles. How long til this goes haywire again??? I'm tellin' ya......
Something is not right here. You should not be getting these spikes in engine temp in winter. My 07 NBS VMAX has never gone over the 210 mark even in summer, and I have not heard the fans come on in months. Could be a bad water pump or a clog in the radiator or even a air bubble in the system. Just my .02
So I take it in on Friday and it does nothing with no signs of a temp spike. I start it with the factory remote this morning, it runs for the 10 minutes and shuts off. Start it again and come out after 2 or 3 minutes and it's blowing cold air, windshield's still frosted, etc. Flip the key over to fire up the gauges, etc., and the temp gauge is reading the 225 to 230 again after no more than a minute. Get out of the subdivision and it drops back to normal and the heat kicks in. Stop on the way to work (5 minutes later)...let it idle for 2 or 3 minutes and I come out and temps back up and now the fan is roaring. Keep in mind it's 19 degrees out. Talk to my sales rep this morning and he tells me a guy we both know is having the same issue with his. Same 2007 Sierra Crew Cab. Don't know if he's got the 4.8 though.
If anyone else is having this issue, gimme a shout. Dropping it off for a loaner tomorrow.
Good detective work LAGA.
Left it there last night and got a call a little while ago that there was an air pocket. Due to a faulty spring clamp that must've leaked anti-freeze some time ago. They checked for leaks when I had it in and I've never had a leak of anything since I've owned it.
Told the service manager of the possible culprit (from suggestions here and otherwise) and got the smartass smirk from the guy when I mentioned, water pump, blockage, and AIR/VAPOR POCKET. Turns out it was just that..they found it by pressurizing the system. You would've thought that when they replaced the thermostat, like last week, they'd have noticed that. Trial and error I guess.
That's why this forum kicks ass.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   1 Member, 0 Anonymous, 1,201 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
