Electric Fans In My 03 1/2ton 5.3l
NDT guy
I am working on installing electric fans on my 03 GM 1/2ton with the 5.3L and need some help with the wiring what I am looking for is a keyed power source under the hood and I also need to know what wire to hook up to for AC
what is wrong with the factory fan?
Other than hurting performance and mpg probably nothing.
Sorry I can't help ya but I've only heard good things when people do this mod.
did sombody dyno this mod to attract this mod?
well considering I work with many people (some former GM TECH's) that also say that it is a good mod to do unfortunately they can't seem to tell me what wires I can use for keyed power and which wire I splice on the AC
Kind of a well known fact among people who work on vehicles and car enthusiast that it frees up power and mpg.
well back to my original issue what wire can I splice into for a keyed power source and also what wire do I splice into for my AC
I know it costs money, but get the wiring harness from Nelson and have the fans turned on from the PCM. A little safer for your wiring and your truck if ya ask me.
Interesting idea ChevyMan23 the only unfortunate part for me is I need my truck ASAP and I am not sure if nelson can ship to canada easily
You can tap into the fuse panel in the engine compartment for the power you need but please use a quality fuse tap like the ones that Buss makes (see link below) otherwise you could cause yourself a few problems with the junk taps. They can be found at most auto parts stores and work fantastic. As far as the A/C you're going to have to find the compressor and tap into the clutch wire. Sounds like you're using a flex-a-lite kit. I've had one on my 02 for a couple of years now and it works great.
http://www.bussmann.com/images/3c2dce34-cf...886ccd13aad.JPG
Be sure and use a piggy back fuse tap of at least 8 or 10 gauge wire. And make sure you power wire is at least 10 gauge. These fans pull some current and need a good stout wire to run them. If you do not have a 140 amp alternator, you may want to look into that as well. The problem that you can have with e fans comes it at idle when other accessories are running such as wipers, heater/AC headlights etc. An Alternator will produce about 40% of it's max output at idle. In other words, if you have a 110 amp alternator, you are producing 44 amps at idle. Not trying to scare you, just a word of caution.
I researched this mod heavily about a year ago and finally gave up on doing it because I use my Yuk XL in towing a 6500 lb camper. I never could get myself comfortable with the e fan set up for towing purposes. This was mostly me just being cautious because I have heard mostly good things about this mod.
it is a flexalite kit that I am useing and all the wiring is provided save for any fuse taps or any clues as to what wire's I can use for the AC and keyed power
Pop the cover off of the fuse box and get yourself a test light and find one that will provide ignition power and use the fuse tap I suggested. Next locate your A/C compressor and find the wire going to the clutch (I think it's green) and use the piggyback splice to tap into it. If you need some pictures I'd be glad to send you some of the installation that I did in my 02.
right on pics would help a lot how did you run the keyed power wire also
    appletrav
    appletrav
  • Who's Online   1 Member, 0 Anonymous, 450 Guests (See full list)
