Engine Hour Meter Malfuction
Today I noticed the hour meter on my truck's DIC was showing only 8.1 hours. My truck is a 2007 Classic 2500HD. It has 14,500 miles. Last I checked was the last time I put fuel in it a couple weeks ago and the hour meter was showing approx. 450 hours. The repair manual says it should only reset itself when it hits 100,000 hours. The hour meter still seems to work as it is still counting up every 6 minutes.
Has anyone had this happen to them? Can I retrieve the lost hours? Do I need to bring it in to the dealer for repair?
Thanks,
Dave
Are you sure you aren't looking at the personal/trip/business hour meter? There are several hour meters on those trucks, if I remember correctly.
It clearly states "ENGINE HOURS" and then the number next to it.
Take it to a dealer, some of the clusters have had problems with the hours resetting. They have a special policy that will goodwill warranty your cluster up to 100,000 kms
don't know what that is in miles. They should replace it for you if it falls under that milage, if they don't want to find a dealer that will.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
