07 Nbs Cc Rear Door Panel Removal
I have an occasional rattle in the Left rear door of my 2007 NBS SLT Crew Cab. I hate to take it in to the dealer for a whole day when I can maybe fix it myself. Usually the squeaks or rattles never seem to show up when the dealer has it. :D I have seen a few posts for removing the rear door panel. Other than the clips on the bottom of the door, are there any other screws to remove?
I will post this info in about 40 mins (i am logging off my work computer and going home)
I have the same rattle on my Silverado. Let us know what you find out. It's too cold out to be messing with the door for me right now.
This is the only info I found:
Document ID# 2045071
2007 Chevrolet Silverado - 2WD
999999995.gifSubject:EI07321 - Inner Door Panel Rattle Noise/Loose (Engineering Information) #07-08-110-010 - (12/13/2007)
Models:2007-2008 Cadillac Escalade, Escalade ESV, Escalade EXT
2007-2008 Chevrolet Avalanche, Silverado, Suburban, Tahoe
2007-2008 GMC Sierra, Yukon, Yukon Denali, Yukon XL
Attention: Proceed with this bulletin ONLY if the customer has commented about this concern AND the EI number is listed in GMVIS. If the customer has not commented about this condition or the EI does not show in GMVIS, disregard this bulletin. THIS IS NOT A RECALL -- refer to TSB 04-00-89-053A for more detail on the use of Engineering Information bulletins.
Condition
Some customers may comment on any of the following conditions:
a rattling noise coming from inside the door or the door panel
a poor fit of the inner door panel
a loose door panel
Cause
GM Engineering is attempting to categorize the several different types of customer comments occurring with door panels on the fullsize pickup and SUV's. This information will be used to quantify each type of specific concern and develop/validate fixes.
During diagnosis and repair, note the following information on the repair order:
Important: If the vehicle is located in SE Michigan, please contact Jerod Long at 586-899-2549. An Engineer may need to physically inspect the vehicle prior to it being repaired.
  1. Describe the customer concern - be specific.
  2. Does the vehicle currently exhibit the condition, or can the condition be easily seen?
  3. Provide a detailed description of the condition causing the customer's concern.
  4. Describe the repair made to correct the customer's concern.
  5. Fax the front and back of the completed repair order to:Attn: Jerod Long
    Fax #: 586-575-0520
Warranty Information
For vehicles repaired under Engineering direction, use:
Labor Operation
Description
Labor Time
C9827*
Door Panel - Engineering Information
0.4 hr
Add:
to repair other side
0.2 hr
* This labor operation number is for bulletin use only. This number will not be published in the Labor Time Guide.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
999999994.gif WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
This might also apply:
Document ID# 2017072
999999995.gifSubject:Roof Panel Flutters When Closing Doors - keywords block body bow door flex foam flutter metal noise rattle roof sheet vibrates #PIT4340B - (09/24/2007)
Models:2007-2008 Cadillac Escalade, ESV, EXT
2007-2008 Chevrolet Avalanche, Suburban, Tahoe
2007-2008 Silverado ( Crew Cab Models Only)
2007-2008 GMC Yukon, Yukon Denali, Yukon XL, Yukon Denali XL
2007-2008 GMC Sierra (Crew Cab Models Only)
This PI was superseded to update models and model years. Please discard PIT4340A.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Some customers may have a concern where the roof panel flutters when closing one of the front side doors. This may be caused by the excessive motion of roof panel. On initial inspection, you may notice that the roof panel expansion adhesive material has separated between the roof and the roof bow. The concern is seen mostly on the first cross bow.
Recommendation/Instructions:
To repair the concern, insert stiff foam blocks between the roof panel and roof bow to "pre-load" roof panel as show in the photo below.
Note: The protective foam block used on the doors of fullsize trucks during shipping from the assembly plant can be used.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
Thank you for the diagram and quick reply. My SLT rear door panel has a one piece handle with the door opening latch above. I can now see where the screws are behind the handle and the door opening latch. Does the fake wood piece on top of the handle holding the power window switch pop off? Does this have to be taken off to remve the panel?
Jay
it should remain on the panel itself, I dont see any screws or connectors behind it............
  • 4 years later...
2008 Suburban LTZ--Drivers side rear door--lock operates to lock, but not to open. Having great difficulty getting door panel off. Is there a secret to removal of the door panel to gain access to power lock motor?
Now that I have the door panel off, what part needs to be replaced? Is the locking mechanism incorporated into the latch? Does anybody know the part number for the door lock? Is there a separete motor for the power locks?
