Fuel Pump Relay Not Engaging
spf72
I am new to this forum and have spent some time doing some research using the search function - while there are a lot of posts on fuel pump issues I have not been able to fix mine so here goes.
Vehicle is a 2000 with a 4.8 Vortec
I replaced my fuel pump and now -
No power coming from the relay - so no prime
changed relay (twice)
11.8 volts on power post of relay
ground post of relay tests good
Pump comes right on and truck runs when I use a jump wire in place of relay
Re-did ground at tank
Relay not puling in - this usally means bad ground - am I missing one?
Tried disconnecting battery to reset ecm
Suggestions???
Thanks
How did you jump across the relay ckt...did you go from a good B+ to the 87 term on the relay output or pin 30 to 87?
I went from 30 to 87 - also checked the grpund side and it's ok. It appears the issue is from the pcm either not sending a signal or a bad wire between the two - now just need to find the pcm!!
The pcm is under the hood, left hand side just behind the radiator (above the steering gear box) and you want connector 2 (the red one)terminal 9 dark green and white wire. There are no other connections in the circuit just the pcm, rear of fuse block and relay.
Thanks, I traced the wire back from the relay and have no power where it feeds the bottom of the fuse block when I turn the key over. I had read that the oil pressure switch feeds power after initial priming? I see no reference to this in my schematic.
If the oil switch is not part then does that mean the PCM is bad? As I said the truck runs fine if I jump out the relay so nothing else appears to be bad on the pcm. How do I check the pcm?
I did pull off the pcm electrical connector and everything appears fine but it is pretty hard to see much. For now I will do a continuity test on the wire - hard to believe only that wire somehow broke as it is in a bundle from the pcm to the relay.
Did you perform a continuity test on that wire? Was it bad? If it's not broken, then there may be a bad connection at the PCM, can you backprobe the connector at the PCM w/ the harness connected to it? It's possible I suppose that somehow the driver in the PCM for that circuit got damaged and only a new PCM will fix it...let us know what you find out.
Thanks to sparkstech I now know the prom on the pcm and I can do a continuity check - there are several green and white wires and I don't have detail on which is which.
Can the drivers be re-programed in the pcm? I know when you buy a new one that they need to program the vin data into it. Can the old one be reprogrammed and load the driver? Probably not worth it as they want $70 just for the program but I was wondering.
And do backprobe do not stick anything into the face of the connector.
May be a stupid question but when you say pull the gray cover off - I had "un-bolted" the conector before which did me no good. Does the top cover snap off? Thanks
If this comes up 3 times I appologize for some reason my postings are not working. I'm not sure what you mean by this did you no good, were you able to remove the connector from the pcm? The cover just snaps off there should be tabs in all four corners that snap in, possibly some in the middle too.
What I meant by doing no good was that the entire conector unplugged but I could not see where the wires went. The connector looked great with no signs of corrosion but I didn't know what pin to check. That is why I asked about the cover. It appeared it would un-snap but I didn't want to break it.
Anyway, I am trying it this morning and will let you know. Also, can this pcm be "re-programmed" or is it best just to replace it?
Brought the pcm to NAPA and had it tested before I bought a new one - old one tested fine except for a fuel pump code so I had them re-set it. Pluged it in and - no difference.
I can have them "re-flash" my pcm and try it again or put in a new one. Issue is my current one cheks out fine so I hate to buy something I don't need and I am not sure what flashing the old one will accomplish. Any ideas what drives the pcm fuel pump output??? My scematic doesn't show it. Hate to replace the pcm and then find out it is some other loose wire somewhere.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   0 Members, 0 Anonymous, 1,145 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
